Aller au contenu principal
Sony TCM-450 Back Cabinet Replacement
Callie Ann Brigance
Callie Ann Brigance et 3 autres contributeurs
Dernière mise à jour le December 30, 2024
5 - 15 minutes
Facile
If your Sony TCM-450 back cabinet is broken or you need to get inside the device then use the guide to remove the back cabinet. The back cabinet is the main piece protecting the speaker and circuit board. To remove the back cabinet it is simple and easy.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Sony TCM-450 Back Cabinet Replacement, Back Cabinet: étape 1, image 1 de 3 Sony TCM-450 Back Cabinet Replacement, Back Cabinet: étape 1, image 2 de 3 Sony TCM-450 Back Cabinet Replacement, Back Cabinet: étape 1, image 3 de 3
    • Remove the two 3.5 mm Phillips #00 screws from the bottom of the device.
    • Caution: Ensure the device is off and unplugged if using the power adapter, as it is unsafe to remove the cabinet while on and will cause damage and potential harm to the user.
  2. Sony TCM-450 Back Cabinet Replacement: étape 2, image 1 de 3 Sony TCM-450 Back Cabinet Replacement: étape 2, image 2 de 3 Sony TCM-450 Back Cabinet Replacement: étape 2, image 3 de 3
    • Open the lid, and carefully remove the two 9.7 mm Phillips #0 screws from the inside of the front cabinet.
    • Exercise caution while removing these screws, as damage to essential parts may occur and other minor damages may occur if the screwdriver slips.
  3. Sony TCM-450 Back Cabinet Replacement: étape 3, image 1 de 3 Sony TCM-450 Back Cabinet Replacement: étape 3, image 2 de 3 Sony TCM-450 Back Cabinet Replacement: étape 3, image 3 de 3
    • Open the battery cover, and gently remove the back cabinet with the iFixit Opening tool.
    • The device will make a popping sound when removing the back cabinet. The back cabinet may feel as if it is not loose. However, as long as the back cabinet looks disconnected from the lid, it is safe to remove.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Callie Ann Brigance
Membre depuis le 09/25/24
453 Réputation
4 tutoriels rédigés
Équipe
University of Memphis, Team 1-3, Sneed Fall 2024 Membre de l'équipe University of Memphis, Team 1-3, Sneed Fall 2024
UM-SNEED-F24S1G3
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 21
Total : 72
