Sony Xperia XA1 Ultra Back Camera Replacement
Introduction
Passez à l'étape 1This guide will show you how to remove the back camera from your Sony Xperia XA1 Ultra. The back camera will need to be replaced if it is cracked or damaged. A heat gun or hairdryer is needed to open the back panel, which can become hot and potentially damage the phone. Additionally, a spudger is needed to lift the camera from the phone.
Ce dont vous avez besoin
Wedge your finger under the bottom ridge of the SD card insert.
Pull outwards with your fingers to remove the SD card from the left side of device.
Outil utilisé dans cette étape :Plastic Cards$2.99
Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
Remove the four 4mm T5 screws on the top of the black panel securing the antenna module to the device.
Insert your iFixit Opening Tool between the back camera and the motherboard and gently lift up.
Lift up with the iFixit Opening Tool until the back camera is removed from the device.
2 autres ont terminé cette réparation.
