Introduction
Sony Xperia Z2 (D6502, D6503, and D6543) - How to replace the Logic Board (Main Board).
Pièces
Aucune pièce spécifiée.
Vidéo d'introduction
Switch off the phone.
If you can't switch it off, you can use the OFF button near to the SIM card Tray.
Warm the Back Cover. You can use a hairdryer.
Disconnect the Battery Flex Cable and remove the two Philips screws.
Li-Polymer Battery, 3.8V, 3200mAh
Part number: LIS1543ERPC
Disconnect one by one:
Magnetic Charging Dock Flex Cable
Volume / Power Button and Microphone Flex Cable
Main Camera
Audio Jack and Light Sensor Flex cable
Coaxial Antenna Cable
19 autres ont terminé cette réparation.
3 commentaires
Hi
Do anyone knows where I can buy a logic board for Xperia Z2?
https://www.ebay.com/sch/i.html?_from=R4...
or I bought there
https://ru.aliexpress.com/wholesale?catI...
be careful to find cheaper price and for your model D6503 or D6563…
Are you sure Phillips #00 is the correct size of screwdriver? I had difficulty getting one of the screws to turn (the screwdriver kept slipping), so I tried the other sizes in my iOpener Kit and found that the PH#000 seemed to fit them better, and that screw came straight out with it.
