Soundproofing a Door with Door Gap Tape
Introduction
Passez à l'étape 1This guide is intended to show the user how to fix any door gaps using door gap tape. Over time, doors and thresholds will warp naturally due to moisture escaping from wood. This may lead to irregular angles forming between the door and the threshold, allowing light and sound to come through. Available at many retailers, door gap tape comes in a variety of thicknesses, allowing for a proper seal no matter the width of the gap.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
Stand on the side of the door you are attempting to prevent light and sound from entering and illuminate the opposing side with a light source.
Inspect the gap tape door seal and make sure that: the door can shut fully, the gap tape is the correct width, and that the tape is in the correct area.
If there are any sufficiently large or irregular gaps, consider using a thicker width of door gap tape in those specific sections or applying a second layer of door gap tape if the dimensions allow.
Open the door and remove the temporarily stuck door gap tape. Be sure to remove any double-sided tape that might be stuck to the door.
Clean the area of the application using a cotton ball (or any other disposable cloth) and rubbing alcohol.
If you are attaching the door gap tape to the door, clean the side of the door instead of the threshold.
Remove the adhesive protector on the back of the gap tape and apply the gap tape to the target area.
Make sure to apply the tape gradually, peeling the protector back as the exposed adhesive touches the application surface.
Repeat this step for any other sections present.
If the application is not to your liking, gently remove the tape by peeling back the adhesive strip and re-clean the area with alcohol before re-taping.
The gap previously present should be gone or at least significantly diminished. To remove the door gap tape for any reason, gently peel back the tape and clean any lingering adhesive with isopropyl alcohol. Peeling back the tape aggressively may result in damage to the door paint depending on the strength of the adhesive present.
