Aller au contenu principal
SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement
Kyle Chang
Kyle Chang et 2 autres contributeurs
Dernière mise à jour le June 29, 2022
15 minutes
Modérée
If the headset mute button is broken or not pressing down properly, follow this guide to replace the button cap.
Ce dont vous avez besoin
Outils
  1. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement, Headset Ear Cushions: étape 1, image 1 de 2 SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement, Headset Ear Cushions: étape 1, image 2 de 2
    • Lift the edge of the cushion and pull out slightly.
    • Work your way around the cushion until it comes off completely.
    • Repeat for the other cushion.
  2. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement, Headset Circuit Board: étape 2, image 1 de 1
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
  3. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement: étape 3, image 1 de 1
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement: étape 4, image 1 de 1
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement: étape 5, image 1 de 1
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
  6. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement, Headset Mute Button Cap: étape 6, image 1 de 2 SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement, Headset Mute Button Cap: étape 6, image 2 de 2
    • Flip the circuit board over and remove the keycap by pulling on it.
6 autres ont terminé cette réparation.
Kyle Chang
Membre depuis le 01/24/19
1 170 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team S18-G1, White Winter 2019 Membre de l'équipe Cal Poly, Team S18-G1, White Winter 2019
CPSU-WHITE-W19S18G1
4 membres
21 tutoriels rédigés
2 commentaires de tutoriel
Can you provide a part number or link to order the replacement mute button cap?
Pete - Réponse
Did you find the part number?
Robby -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 38
Total : 7,795
