Aller au contenu principal
TOSHIBA Satellite E45W-C4200X TrackPad Replacement
Hudson Bennett
Hudson Bennett et 3 autres contributeurs
Dernière mise à jour le January 8, 2023
10 - 20 minutes
Modérée
With this guide, you will be able to learn how to replace your Trackpad on your Toshiba Satellite E45W-C4200X.
The trackpad is vital tool for controlling your curser on your computer.
Before using this guide, make sure to review the troubleshooting page to ensure theTrackpad will need to be replaced.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. TOSHIBA Satellite E45W-C4200X TrackPad Replacement, Battery: étape 1, image 1 de 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement, Battery: étape 1, image 2 de 2
    • Remove the ten 1 mm screws that secure the back cover using a Phillips #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: étape 2, image 1 de 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: étape 2, image 2 de 2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
    • Lift and remove the casing.
  3. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: étape 3, image 1 de 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: étape 3, image 2 de 2
    • Gently lift the flap covering the top side of the battery.
  4. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: étape 4, image 1 de 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: étape 4, image 2 de 2
    • Remove the four 0.5 mm screws that hold the battery in using the Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: étape 5, image 1 de 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: étape 5, image 2 de 2
    • Unplug the battery from the motherboard.
  6. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: étape 6, image 1 de 1
    • Remove the battery from the laptop.
  7. TOSHIBA Satellite E45W-C4200X TrackPad Replacement, TrackPad: étape 7, image 1 de 1
    • Use the heat gun to heat the top of the keyboard cover to loosen the adhesive.
  8. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: étape 8, image 1 de 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: étape 8, image 2 de 2
    • Use the spudger to peel up the keyboard cover.
    • Use caution when removing keyboard cover.
  9. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: étape 9, image 1 de 3 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: étape 9, image 2 de 3 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: étape 9, image 3 de 3
    • Use the heat gun to apply heat to the track pad and use the metal spudger to remove the track pad.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 350
