Aller au contenu principal
Teenage Engineering OP-1 Keyboard Replacement
Tobias Isakeit
Tobias Isakeit
Dernière mise à jour le October 5, 2023
30 minutes
Modérée
No keyboard no sound. It's easy as that. But don't be afraid, replacing it is also very easy.
This guide shows you how to replace the keyboard of your OP-1.
Ce dont vous avez besoin
Pièces
Outils
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. Teenage Engineering OP-1 Keyboard Replacement, key removal: étape 1, image 1 de 3 Teenage Engineering OP-1 Keyboard Replacement, key removal: étape 1, image 2 de 3 Teenage Engineering OP-1 Keyboard Replacement, key removal: étape 1, image 3 de 3
    • To get to the screws beneath the keyboard you need to take some keys off. You can use either an opening tool or an opening pick. The first picture shows how it should look like with all the necessary keys off (12 in total).
    • The four longer keys from the fingerboard are to be handled from the left side to get them off.
    • The eight smaller keys need to be levered from the bottom up.
  2. Teenage Engineering OP-1 Keyboard Replacement, removing scissors mechanisms: étape 2, image 1 de 2 Teenage Engineering OP-1 Keyboard Replacement, removing scissors mechanisms: étape 2, image 2 de 2
    • The scissor mechanism of the eight small keys are obstructing the underlying screws.
    • By using again an opening tool or opening pick these can be snapped off easily.
    • When reassembling be sure to place them in with the correct side facing upwards.
  3. Teenage Engineering OP-1 Keyboard Replacement, unscrew keyboard: étape 3, image 1 de 3 Teenage Engineering OP-1 Keyboard Replacement, unscrew keyboard: étape 3, image 2 de 3 Teenage Engineering OP-1 Keyboard Replacement, unscrew keyboard: étape 3, image 3 de 3
    • Loosen those 12 screws with a Phillips #00 screwdriver.
    • Then just pull off the four rotary knobs and the volume knob.
    • Now it is possible to slightly lift the keyboard and set it back.
  4. Teenage Engineering OP-1 Keyboard Replacement, Keyboard Connection: étape 4, image 1 de 2 Teenage Engineering OP-1 Keyboard Replacement, Keyboard Connection: étape 4, image 2 de 2
    • Unlock the flex cables by pushing the two black nibs on both sides of each connector.
    • Now you can pull the flex cables out and remove the keyboard completely.
    • When installing the new keyboard, make sure to remove the protective film underneath the screen.
    • The OP-1 has a mode to test specific functions. You can enter it by holding the "COM" button while powering on, then choose the function test (2). You don't have to complete every test and can power off after the keyboard test.
19 autres ont terminé cette réparation.
Tobias Isakeit
Membre depuis le 03/31/14
124 977 Réputation
189 tutoriels rédigés
Équipe
Tobias Isakeit - Repairability Engineer Membre de l'équipe Tobias Isakeit - Repairability Engineer
Business
1 membre
1 132 tutoriels rédigés
19 commentaires de tutoriel
Nice guide Tobias!
Worked like a charm. My OP-1 feels brand new.
Thanks iFixit X TeenageEngineering for providing these replacement parts!
Keep it up <3
Flavius Ivancu - Réponse
Awesome guide! Thank you!!!
Jason Wasiak - Réponse
After reassembling everything I have one key ( the upper A) which retriggers the sound randomly if I press the key.
I hope that the reason is not that I put the flex cable back too loose … and i have to open it again. Anyone had this before?
Raimund S - Réponse
This happened to me constantly, only by taking the key off I noticed the tiniest amount of moisture, a mere misting, nesting in the board. it had been re-triggering randomly… Not ideal whilst constantly gigging. Seems to be triggering normally now after drying it in front of a heater. The only thing I think could of caused this is a dry ice machine I played beside a few weeks ago.
Qaiyyum Tajudin -
Perfect. Thanks :)
kristianottosen - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 58
30 derniers jours : 233
Total : 32,686
