Aller au contenu principal
ThinkPad Edge E31 Wireless Card Replacement
Riley
Riley et 3 autres contributeurs
Dernière mise à jour le May 10, 2017
6 minutes
Facile
Your wireless card will allow you to connect to wireless networks. If it is not functioning, you may not be able to access the internet. This guide will show you how to replace it.
Ce dont vous avez besoin
  1. ThinkPad Edge E31 Wireless Card Replacement, Battery: étape 1, image 1 de 1
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
  2. ThinkPad Edge E31 Wireless Card Replacement: étape 2, image 1 de 1
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
  3. ThinkPad Edge E31 Wireless Card Replacement, ThinkPad Edge E31 Underside Disassembly: étape 3, image 1 de 1
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
  4. ThinkPad Edge E31 Wireless Card Replacement, Wireless Card: étape 4, image 1 de 1
    • The wireless card is located above the Hard drive and RAM on the exposed laptop.
    • There are 2, 4mm long M2 screws holding the wireless card to the laptop. Unscrew the screws.
  5. ThinkPad Edge E31 Wireless Card Replacement: étape 5, image 1 de 1
    • Once the screws are removed, there will be 2 wires attached to the card. These can be easily popped off by hand to fully disconnect the card form the laptop.
Riley
Membre depuis le 03/19/17
601 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G5, Isaacson Spring 2017 Membre de l'équipe UMass Dartmouth, Team S6-G5, Isaacson Spring 2017
UMASSD-ISAACSON-S17S6G5
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 8
Total : 182
