Toilet Tree TTP-TRIM-1 Blade Replacement
Introduction
Passez à l'étape 1The blades on the Nose & Ear trimmer eventually wear out and require replacement. The following steps will guide you through how to safely and successfully replace these blades.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
Twist the tip of the trimmer counterclockwise to remove it.
The trimmer blade assembly will be located on the inside of the tip.
