Toshiba Satellite A105-S4284 CPU(Central Processor Unit) Replacement
Ce dont vous avez besoin
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Remove the upper half of laptop and place bottom half in the center of your workspace.
Remove the one 2.00mm phillips screw.
Remove the ribbon cable connecting the USB ports to the motherboard.
Rotate the locking screw holding the CPU in, counter clockwise 180 degrees.
3 autres ont terminé cette réparation.
Un commentaire
When I replaced the old battery by the new one ,a message "4 minute to full charge ".some one told me there is a process to do .what is this process???
