Aller au contenu principal
Toshiba Satellite A65-S126 Speaker Replacement
Cole Uhland
Cole Uhland et 7 autres contributeurs
Dernière mise à jour le November 17, 2022
Aucune estimation
Modérée
This is a step by step guide of how to replace the speakers in case of malfunction or upgrade.
Ce dont vous avez besoin
Outils
  1. Toshiba Satellite A65-S126 Speaker Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Toshiba Satellite A65-S126 Speaker Replacement: étape 2, image 1 de 1
    • Gently lift the battery out of the computer.
  3. Toshiba Satellite A65-S126 Speaker Replacement, Upper Assembly: étape 3, image 1 de 1
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Toshiba Satellite A65-S126 Speaker Replacement: étape 4, image 1 de 1
    • Remove the WIFI module cover. It will pull right off.
  5. Toshiba Satellite A65-S126 Speaker Replacement: étape 5, image 1 de 2 Toshiba Satellite A65-S126 Speaker Replacement: étape 5, image 2 de 2
    • Unplug the white and black wires from the WiFi module.
  6. Toshiba Satellite A65-S126 Speaker Replacement: étape 6, image 1 de 1
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Toshiba Satellite A65-S126 Speaker Replacement: étape 7, image 1 de 1
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Toshiba Satellite A65-S126 Speaker Replacement: étape 8, image 1 de 1
    • Use the plastic opening tool to pry the two halves apart.
  9. Toshiba Satellite A65-S126 Speaker Replacement, Speaker: étape 9, image 1 de 2 Toshiba Satellite A65-S126 Speaker Replacement, Speaker: étape 9, image 2 de 2
    • Locate the plug for the speaker wires on the bottom of the laptop.
  10. Toshiba Satellite A65-S126 Speaker Replacement: étape 10, image 1 de 1
    • Unplug the speaker wire connector.
  11. Toshiba Satellite A65-S126 Speaker Replacement: étape 11, image 1 de 1
    • Remove the speakers by sliding them straight up. They should slide out with ease.
Cole Uhland
Membre depuis le 09/30/13
216 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 14-8, Forte Fall 2013 Membre de l'équipe Cal Poly, Team 14-8, Forte Fall 2013
CPSU-FORTE-F13S14G8
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 581
