Toshiba Satellite C55-B5302 Monitor Screen Replacement
Introduction
Passez à l'étape 1These are the steps for removing the monitor screen from your Toshiba Satellite C55-B5302 laptop. Before starting, make sure you have your Phillips size #0 screwdriver and a systematic way to keep all the unscrewed screws as there are going to be a large number of them with different dimensions. Since we will be working in close proximity with the monitor screen, you should be careful not to scratch it.
Ce dont vous avez besoin
Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
After the fan has been removed, lift the hinge so as to get access to the parts below it.
Remove the the black colored cable that is now exposed.
Remove the three 4.1 mm Phillips #0 screws attaching each hinge to the screen.
Have the screen along with the metal hinges stand upright on one side.
Remove the three 3 mm Phillips #0 screws from the metal frame attached to the hinge.
Separate the metal frame from the rest of the screen.
