Aller au contenu principal
Toshiba Satellite C55D-B5310 Touchpad Replacement
Crystal Loomis
Crystal Loomis et 2 autres contributeurs
Dernière mise à jour le December 15, 2022
30 minutes
Difficile
If you are unable to use the touchpad of your laptop, use this guide to remove and replace the touchpad.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Toshiba Satellite C55D-B5310 Touchpad Replacement, Keyboard: étape 1, image 1 de 2 Toshiba Satellite C55D-B5310 Touchpad Replacement, Keyboard: étape 1, image 2 de 2
    • Turn off your device before starting.
    • Flip the phone over so that the back camera is facing you.
  2. Toshiba Satellite C55D-B5310 Touchpad Replacement: étape 2, image 1 de 3 Toshiba Satellite C55D-B5310 Touchpad Replacement: étape 2, image 2 de 3 Toshiba Satellite C55D-B5310 Touchpad Replacement: étape 2, image 3 de 3
    • Use a your hands to remove the backing of the phone.
    • Use your phillips screwdriver to begin removing all the accesible screws.
    • Now begin to remove the coverings above and below the middle plate with your hand.
    • use your hand or a tool to remove the tabbing on the metal plate covering the battery.
    • Remove the metal plate covering the battery.
    • Use your wedging tool to begin removeing the adhesive under the battery.
    • Remove these two screws with your phillips screw driver.
    • Open the two metal tabs
    • Flip the phone back over with the screen facing you.
    • Begin to use the wedging tool to remove the space bar off of the keyboard.
    • remove the screws on each end of the space bars vacant lcoation.
    • Grab the wedging tool and begin wedging the old keyboard.
    • begind wedging the back of the keyboard until free.
    • Begin deperating the keyboard from the backing.
    • grab your replacement keyboard and connect it to the backing of the old keyboard.
    • place the keyboard back onto the front of the phone
    • once placed, hold the keyboard onto the phone while clicking the two metal plates back down to connect the keyboard.
  3. Toshiba Satellite C55D-B5310 Touchpad Replacement, CD/DVD Drive: étape 19, image 1 de 1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
  4. Toshiba Satellite C55D-B5310 Touchpad Replacement: étape 20, image 1 de 2 Toshiba Satellite C55D-B5310 Touchpad Replacement: étape 20, image 2 de 2
    • Slide the CD/DVD Drive out of the laptop.
  5. Toshiba Satellite C55D-B5310 Touchpad Replacement, Touchpad: étape 21, image 1 de 1
    • Remove the thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
  6. Toshiba Satellite C55D-B5310 Touchpad Replacement: étape 22, image 1 de 2 Toshiba Satellite C55D-B5310 Touchpad Replacement: étape 22, image 2 de 2
    • Using the plastic opening tools, separate the back cover from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the plastic back cover.
  7. Toshiba Satellite C55D-B5310 Touchpad Replacement: étape 23, image 1 de 2 Toshiba Satellite C55D-B5310 Touchpad Replacement: étape 23, image 2 de 2
    • Release the clamps holding the white ribbon between the touchpad component and the motherboard.
    • Slide the ribbon from the motherboard connection socket.
  8. Toshiba Satellite C55D-B5310 Touchpad Replacement: étape 24, image 1 de 1
    • Remove the two 7 mm Phillips screws holding the touchpad component to the back panel using the PH1 bit and Magnetic Driver.
  9. Toshiba Satellite C55D-B5310 Touchpad Replacement: étape 25, image 1 de 2 Toshiba Satellite C55D-B5310 Touchpad Replacement: étape 25, image 2 de 2
    • Release the two clamps connecting the blue ribbon to the external touchpad.
    • Lift the black clasp holding the blue ribbon in place.
  10. Toshiba Satellite C55D-B5310 Touchpad Replacement: étape 26, image 1 de 2 Toshiba Satellite C55D-B5310 Touchpad Replacement: étape 26, image 2 de 2
    • Slide the blue ribbon from the external touchpad holding socket.
    • Lift the touchpad module from the laptop.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 9
Total : 972
