Aller au contenu principal
Toshiba Satellite C55D-C5106 Disk Drive Replacement
Laura Tamayo
Laura Tamayo et un autre contributeur
Dernière mise à jour le December 15, 2022
7 minutes
Facile
In the case you need to replace the disk drive of your Toshiba Satellite C55D-C5106, this guide will aid you through the process.
Ce dont vous avez besoin
Outils
  1. Toshiba Satellite C55D-C5106 Disk Drive Replacement, Disk Drive: étape 1, image 1 de 3 Toshiba Satellite C55D-C5106 Disk Drive Replacement, Disk Drive: étape 1, image 2 de 3 Toshiba Satellite C55D-C5106 Disk Drive Replacement, Disk Drive: étape 1, image 3 de 3
    • Turn the laptop off and remove any external power sources.
    • Flip the laptop upside down.
    • Remove all of the 12 screws that secure the back cover to the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite C55D-C5106 Disk Drive Replacement: étape 2, image 1 de 1
    • Pull the battery toward yourself until it is completely removed from the laptop. The battery should detach easily.
  3. Toshiba Satellite C55D-C5106 Disk Drive Replacement: étape 3, image 1 de 1
    • Run the metal spudger around the seam between the back cover and the rest of the laptop.
  4. Toshiba Satellite C55D-C5106 Disk Drive Replacement: étape 4, image 1 de 3 Toshiba Satellite C55D-C5106 Disk Drive Replacement: étape 4, image 2 de 3 Toshiba Satellite C55D-C5106 Disk Drive Replacement: étape 4, image 3 de 3
    • Use the metal spudger to remove the bottom cover of the laptop.
  5. Toshiba Satellite C55D-C5106 Disk Drive Replacement: étape 5, image 1 de 2 Toshiba Satellite C55D-C5106 Disk Drive Replacement: étape 5, image 2 de 2
    • Remove the disk drive by gently pulling it up and sliding it out.
Laura Tamayo
Membre depuis le 02/14/19
678 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G4, Leahy Spring 2019 Membre de l'équipe USF Tampa, Team S1-G4, Leahy Spring 2019
USFT-LEAHY-S19S1G4
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 341
