Aller au contenu principal
Toshiba Satellite C655-S5142 RAM Replacement
Hunter Gonsalves
Hunter Gonsalves et un autre contributeur
Dernière mise à jour le December 23, 2022
2 minutes
Facile
If you are having issue with your RAM, this guide will walk you through replacing the parts. The only tool needed is a PH1 Philips head screwdriver.
Ce dont vous avez besoin
  1. Toshiba Satellite C655-S5142 RAM Replacement, RAM: étape 1, image 1 de 2 Toshiba Satellite C655-S5142 RAM Replacement, RAM: étape 1, image 2 de 2
    • Ensure that your laptop is turned off and the battery has been removed
    • Flip over your laptop where the battery side is closest to you.
  2. Toshiba Satellite C655-S5142 RAM Replacement: étape 2, image 1 de 2 Toshiba Satellite C655-S5142 RAM Replacement: étape 2, image 2 de 2
    • Unscrew the singlular screw in plate with a Phillips #1 screwdriver.
    • The screw does not come all the way out of the plastic plating, instead there is a protector that keeps it in place for you even when fully unscrewed.
  3. Toshiba Satellite C655-S5142 RAM Replacement: étape 3, image 1 de 3 Toshiba Satellite C655-S5142 RAM Replacement: étape 3, image 2 de 3 Toshiba Satellite C655-S5142 RAM Replacement: étape 3, image 3 de 3
    • To remove the RAM sticks, put your thumbs on the metal pins and push outwards.
    • Once pushed outwards, the first RAM stick will pop up at an angle
    • After the RAM is at an angle, you can now remove that stick of RAM and repeat the process to the second stick of RAM.
Hunter Gonsalves
Membre depuis le 03/24/19
121 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S1-G5, Valliere Spring 2019 Membre de l'équipe UMass Dartmouth, Team S1-G5, Valliere Spring 2019
UMASSD-VALLIERE-S19S1G5
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 252
