Toshiba Satellite C855D-S5303 RAM Replacement
Introduction
Passez à l'étape 1This guide will show you how to remove your laptops RAM. This process requires a small Phillips Head screwdriver and your hands. There will be several small screws removed, so be sure you have a place to store them as you work to keep from losing any.
Ce dont vous avez besoin
Using a small Phillip's head screwdriver, unscrew the single 7 mm screw (5 mm head) on the L-shaped panel on the backside of the laptop.
Once the screw is removed, pry the panel upwards by gripping the groove pictured.
