Aller au contenu principal
Toshiba Satellite CL15t-B1204X  Speaker Replacement
Royce Alexander Porter
Royce Alexander Porter et 2 autres contributeurs
Dernière mise à jour le December 30, 2022
10 minutes
Modérée
A besoin de meilleures images
Meilleure introduction
Ce dont vous avez besoin
Outils
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Toshiba Satellite CL15t-B1204X  Speaker Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X  Speaker Replacement: étape 2, image 1 de 1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X  Speaker Replacement: étape 3, image 1 de 1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X  Speaker Replacement: étape 4, image 1 de 1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X  Speaker Replacement: étape 5, image 1 de 1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X  Speaker Replacement: étape 6, image 1 de 1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X  Speaker Replacement, Speaker: étape 7, image 1 de 2 Toshiba Satellite CL15t-B1204X  Speaker Replacement, Speaker: étape 7, image 2 de 2
    • Carefully unplug the speaker's cord from the I/O board.
  8. Toshiba Satellite CL15t-B1204X  Speaker Replacement: étape 8, image 1 de 2 Toshiba Satellite CL15t-B1204X  Speaker Replacement: étape 8, image 2 de 2
    • Unscrew the two 3mm screws with the PH1 screw head on each speaker found on the corner's away from the hinges.
  9. Toshiba Satellite CL15t-B1204X  Speaker Replacement: étape 9, image 1 de 1
    • Remove the speakers.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 212
