Aller au contenu principal
Toshiba Satellite Click 2 L35W-B3204 Battery Replacement
Lexi Lannigan
Lexi Lannigan et 5 autres contributeurs
Dernière mise à jour le February 13, 2025
5 - 10 minutes
Modérée
Étudiant en action
Détails manquants
If your laptop dies quickly after unplugging the power adapter, this guide will help you solve that problem by replacing the battery. This replacement only requires the screen portion of the laptop, so remove the keyboard before beginning.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Toshiba Satellite Click 2 L35W-B3204 Battery Replacement, Screen: étape 1, image 1 de 3 Toshiba Satellite Click 2 L35W-B3204 Battery Replacement, Screen: étape 1, image 2 de 3 Toshiba Satellite Click 2 L35W-B3204 Battery Replacement, Screen: étape 1, image 3 de 3
    • Begin by inserting the plastic opening tool into the lip that lies between the screen and the plastic housing and gently prying it open. The best place to begin the screen removal is the bottom left side of the screen.
    • Continue to work your way around the screen with the opening tool until all the clips are undone and the screen is free.
    • Lift screen off of plastic cover to expose the internal components.
  2. Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: étape 2, image 1 de 3 Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: étape 2, image 2 de 3 Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    • Locate the wide, golden connection on the bottom of the screen. Use the black spudger to peel away the tape holding it in place.
    • Use tweezers to gently remove the plug from the screen.
  3. Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: étape 3, image 1 de 3 Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: étape 3, image 2 de 3 Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: étape 3, image 3 de 3
    • Trace the black ribbon cable that begins on the right of the screen. This cable is connected to the upper part of the motherboard, which is located near the right speaker.
    • Using tweezers, gently grasp the plug on the end of the ribbon cable and remove it from the motherboard.
  4. Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: étape 4, image 1 de 1
    • Your screen is now completely detached from the internal components.
  5. Toshiba Satellite Click 2 L35W-B3204 Battery Replacement, Battery: étape 5, image 1 de 1
    • Remove the copper shield by removing the four Phillips screws that hold the shield in place.
  6. Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: étape 6, image 1 de 1
    • Unplug the battery from the motherboard by pushing the white clip with a metal spudger. You can attempt to use the plastic spudger first, but it may be more difficult.
  7. Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: étape 7, image 1 de 2 Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: étape 7, image 2 de 2
    • Remove 2 6mm Phillips #0 screws holding the battery in place.
  8. Toshiba Satellite Click 2 L35W-B3204 Battery Replacement: étape 8, image 1 de 1
    • Remove the battery by lifting on the left side, while holding the ribbon cable above it out of the way.
Lexi Lannigan
Membre depuis le 10/17/18
753 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G4, Valliere Fall 2018 Membre de l'équipe UMass Dartmouth, Team S1-G4, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G4
6 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 6
Total : 914
