Toshiba Satellite E105-S1602 Charging Port Replacement
Introduction
Passez à l'étape 1The charging port is where the charging cord connects into the device. If your device will not charge with the cord plugged in, it may need a new charging port.
Ce dont vous avez besoin
Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
Pry the top plastic strip from the top of the keyboard.
Peel the strip completely away from the keyboard.
Locate the four silver screws on the front panel.
Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
Use the plastic opening tool to pry the top panel up from the base of the computer.
Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base.
Disconnect ribbons, and slowly lift the top panel up, away from the base.
2 autres ont terminé cette réparation.
