Aller au contenu principal
Toshiba Satellite E105-S1602 Keyboard Replacement
Ian Washburne
Ian Washburne et 9 autres contributeurs
Dernière mise à jour le January 2, 2023
Aucune estimation
Très facile
Meilleure introduction
Use this guide when your keyboard does not work or if any keys falls off. You cannot replace individual keys.
Ce dont vous avez besoin
Outils
  1. Toshiba Satellite E105-S1602 Keyboard Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite E105-S1602 Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Slide both of the latches to the outside to release the battery.
  2. Toshiba Satellite E105-S1602 Keyboard Replacement: étape 2, image 1 de 2 Toshiba Satellite E105-S1602 Keyboard Replacement: étape 2, image 2 de 2
    • Pull the battery out by lifting the battery cover away from the laptop.
  3. Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: étape 3, image 1 de 3 Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: étape 3, image 2 de 3 Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: étape 3, image 3 de 3
    • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
    • Pry the top plastic strip from the top of the keyboard.
    • Peel the strip completely away from the keyboard.
  4. Toshiba Satellite E105-S1602 Keyboard Replacement: étape 4, image 1 de 2 Toshiba Satellite E105-S1602 Keyboard Replacement: étape 4, image 2 de 2
    • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  5. Toshiba Satellite E105-S1602 Keyboard Replacement: étape 5, image 1 de 2 Toshiba Satellite E105-S1602 Keyboard Replacement: étape 5, image 2 de 2
    • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
    • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  6. Toshiba Satellite E105-S1602 Keyboard Replacement: étape 6, image 1 de 1
    • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  7. Toshiba Satellite E105-S1602 Keyboard Replacement: étape 7, image 1 de 1
    • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  8. Toshiba Satellite E105-S1602 Keyboard Replacement: étape 8, image 1 de 2 Toshiba Satellite E105-S1602 Keyboard Replacement: étape 8, image 2 de 2
    • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
    • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
Ian Washburne
Membre depuis le 01/11/13
59 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 17-21, Forte Winter 2013 Membre de l'équipe Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,595
