Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement
10 minutes
Modérée
Introduction
Passez à l'étape 1Use this guide to replace a defective fan and heatsink in a Toshiba Satellite E45t-B4300.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Plastic Cards$2.99
Run the spudger or a plastic card around the entire laptop to release the rest of the clips.
Remove the four 2mm screws with a Phillips #0 screwdriver.
Remove the two 2mm screws with a Phillips #0 screwdriver.
Presque terminé !
