Aller au contenu principal
Toshiba Satellite E45t-B4300 Hard Drive Replacement
Joshua Swanson
Joshua Swanson et 2 autres contributeurs
Dernière mise à jour le January 7, 2023
10 minutes
Modérée
Use this guide to replace the hard drive in a Toshiba Satellite E45t-B4300.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Toshiba Satellite E45t-B4300 Hard Drive Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite E45t-B4300 Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Power off your laptop before continuing.
    • Remove the following two 4mm screws with a Phillips #0 screwdriver.
  2. Toshiba Satellite E45t-B4300 Hard Drive Replacement: étape 2, image 1 de 1
    • Slide the battery out towards you.
  3. Toshiba Satellite E45t-B4300 Hard Drive Replacement, Bottom Case: étape 3, image 1 de 1
    • Remove the following twelve 4mm screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite E45t-B4300 Hard Drive Replacement: étape 4, image 1 de 1
    • Use a spudger to depress the six white clips connecting the plastic cover
  5. Toshiba Satellite E45t-B4300 Hard Drive Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    • Run the spudger or a plastic card around the entire laptop to release the rest of the clips.
  6. Toshiba Satellite E45t-B4300 Hard Drive Replacement: étape 6, image 1 de 1
    • Remove the cover and set to the side.
  7. Toshiba Satellite E45t-B4300 Hard Drive Replacement, Hard Drive: étape 7, image 1 de 3 Toshiba Satellite E45t-B4300 Hard Drive Replacement, Hard Drive: étape 7, image 2 de 3 Toshiba Satellite E45t-B4300 Hard Drive Replacement, Hard Drive: étape 7, image 3 de 3
    • Use the point end of the spudger to lift the the clips that attach the two ribbons to the motherboard.
    • Pull out the ribbons from the motherboard.
  8. Toshiba Satellite E45t-B4300 Hard Drive Replacement: étape 8, image 1 de 1
    • Use an opening tool or your fingers to lift the hard drive out of the laptop.
  9. Toshiba Satellite E45t-B4300 Hard Drive Replacement: étape 9, image 1 de 2 Toshiba Satellite E45t-B4300 Hard Drive Replacement: étape 9, image 2 de 2
    • Unplug the hard drive from the motherboard.
3 autres ont terminé cette réparation.
Joshua Swanson
Membre depuis le 02/20/17
701 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S2-G2, Sullivan Spring 2017 Membre de l'équipe USF Tampa, Team S2-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G2
3 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 2,832
