Toshiba Satellite L15W-B1208X Sound Board Replacement
Introduction
Passez à l'étape 1This guide demonstrates how to remove a Toshiba Satellite L15W-B1208X sound card. Reasons you might want to replace your sound card is if your speakers or headphones don’t work, or if your USB ports are unable to connect.
Ce dont vous avez besoin
Use Phillips #1 screwdriver (PH1 bit) to remove the 2mm screw that secures the sound board.
Outil utilisé dans cette étape :Tweezers$4.99
Using the ESD Safe Tweezers Blunt Nose gently pull on the plastic connector that attaches the speaker wiring to the soundboard to disconnect the soundboard from the laptop.
Gently pull the wire away from the soundboard using the ESD Safe Tweezers Blunt Nose.
