Aller au contenu principal
Toshiba Satellite L305D-S5950 Fan Replacement
William
William et 3 autres contributeurs
Dernière mise à jour le July 15, 2014
35 - 40 minutes
Difficile
A besoin de meilleures images
In order to replace the fan in your device the hard drive, keyboard, motherboard cover, and the motherboard need to be removed.
The hard drive needs to be removed since it is connected to the motherboard through a hole bottom section of the motherboard case.
The keyboard needs to be removed due to the cable connecting it to the motherboard interfering with the removal of the top part of the motherboard case.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Toshiba Satellite L305D-S5950 Fan Replacement, Battery: étape 1, image 1 de 1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Fan Replacement: étape 2, image 1 de 2 Toshiba Satellite L305D-S5950 Fan Replacement: étape 2, image 2 de 2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Fan Replacement: étape 3, image 1 de 2 Toshiba Satellite L305D-S5950 Fan Replacement: étape 3, image 2 de 2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Fan Replacement: étape 4, image 1 de 1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Fan Replacement, Hard Disk Drive: étape 5, image 1 de 2 Toshiba Satellite L305D-S5950 Fan Replacement, Hard Disk Drive: étape 5, image 2 de 2
    • Unscrew the screws enough to remove the top cover.
  6. Toshiba Satellite L305D-S5950 Fan Replacement: étape 6, image 1 de 1
    • Remove the cover by lifting the right side up at an angle before removing the entire cover.
  7. Toshiba Satellite L305D-S5950 Fan Replacement: étape 7, image 1 de 2 Toshiba Satellite L305D-S5950 Fan Replacement: étape 7, image 2 de 2
    • Remove the hard drive from the SATA slot by tugging lightly on the ribbon cable to the right.
  8. Toshiba Satellite L305D-S5950 Fan Replacement: étape 8, image 1 de 3 Toshiba Satellite L305D-S5950 Fan Replacement: étape 8, image 2 de 3 Toshiba Satellite L305D-S5950 Fan Replacement: étape 8, image 3 de 3
    • To separate the hard drive from the caddy, unscrew the two screws.
  9. Toshiba Satellite L305D-S5950 Fan Replacement, RAM: étape 9, image 1 de 3 Toshiba Satellite L305D-S5950 Fan Replacement, RAM: étape 9, image 2 de 3 Toshiba Satellite L305D-S5950 Fan Replacement, RAM: étape 9, image 3 de 3
    • Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself.
  10. Toshiba Satellite L305D-S5950 Fan Replacement: étape 10, image 1 de 2 Toshiba Satellite L305D-S5950 Fan Replacement: étape 10, image 2 de 2
    • Push the small levers at the sides of the RAM module away from each other. The RAM module should automatically rotate upwards.
  11. Toshiba Satellite L305D-S5950 Fan Replacement: étape 11, image 1 de 2 Toshiba Satellite L305D-S5950 Fan Replacement: étape 11, image 2 de 2
    • Remove the RAM module by pulling it out at the angle it was rotated to.
  12. Toshiba Satellite L305D-S5950 Fan Replacement: étape 12, image 1 de 3 Toshiba Satellite L305D-S5950 Fan Replacement: étape 12, image 2 de 3 Toshiba Satellite L305D-S5950 Fan Replacement: étape 12, image 3 de 3
    • If you want to replace the second RAM module, apply steps 2 and 3 to do so.
  13. Toshiba Satellite L305D-S5950 Fan Replacement, Keyboard: étape 13, image 1 de 2 Toshiba Satellite L305D-S5950 Fan Replacement, Keyboard: étape 13, image 2 de 2
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  14. Toshiba Satellite L305D-S5950 Fan Replacement: étape 14, image 1 de 1
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  15. Toshiba Satellite L305D-S5950 Fan Replacement: étape 15, image 1 de 3 Toshiba Satellite L305D-S5950 Fan Replacement: étape 15, image 2 de 3 Toshiba Satellite L305D-S5950 Fan Replacement: étape 15, image 3 de 3
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  16. Toshiba Satellite L305D-S5950 Fan Replacement: étape 16, image 1 de 1
    • Remove the keyboard completely from the laptop.
  17. Toshiba Satellite L305D-S5950 Fan Replacement, Motherboard Cover: étape 17, image 1 de 2 Toshiba Satellite L305D-S5950 Fan Replacement, Motherboard Cover: étape 17, image 2 de 2
    • Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
    • Remove all 5.25mm screws from the top of the laptop.
  18. Toshiba Satellite L305D-S5950 Fan Replacement: étape 18, image 1 de 3 Toshiba Satellite L305D-S5950 Fan Replacement: étape 18, image 2 de 3 Toshiba Satellite L305D-S5950 Fan Replacement: étape 18, image 3 de 3
    • Unplug the wires highlighted with red squares.
    • Using a pry tool and yours hands to remove the motherboard cover.
  19. Toshiba Satellite L305D-S5950 Fan Replacement, Motherboard: étape 19, image 1 de 1
    • Unscrew all the screws indicated by the red circles (The bottom two screws are 10.75mm and the top screw is 5mm).
    • Unplug all the wires indicated by the orange squares.
    • Some wires may have a lock on them that needs to be pulled out before the wire is removed.
  20. Toshiba Satellite L305D-S5950 Fan Replacement: étape 20, image 1 de 1
    • At this point the motherboard can be fully removed from the laptop.
  21. Toshiba Satellite L305D-S5950 Fan Replacement, Fan: étape 21, image 1 de 1
    • Using your fingers, disconnect the fan power cord from the motherboard.
  22. Toshiba Satellite L305D-S5950 Fan Replacement: étape 22, image 1 de 2 Toshiba Satellite L305D-S5950 Fan Replacement: étape 22, image 2 de 2
    • Using your fingers, disconnect the fan from the heatsink.
William
Membre depuis le 03/26/14
889 Réputation
7 tutoriels rédigés
Équipe
Clemson, Team 1-2, Benson Spring 2014 Membre de l'équipe Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 876
