Aller au contenu principal
Toshiba Satellite L45-S7423 Wireless Card Replacement
Stephen Sippel
Stephen Sippel et 4 autres contributeurs
Dernière mise à jour le June 14, 2023
5 - 10 minutes
Modérée
Tutoriel étudiant vedette
The wireless card allows the user to wirelessly connect to the internet if WiFi is available. If you are experiencing trouble with your wireless connection, replacement of your wireless card may be necessary. Following the this guide will allow you to easily replace your wireless card.
Ce dont vous avez besoin
Outils
  1. Toshiba Satellite L45-S7423 Wireless Card Replacement, Battery: étape 1, image 1 de 3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Battery: étape 1, image 2 de 3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Battery: étape 1, image 3 de 3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Wireless Card Replacement: étape 2, image 1 de 2 Toshiba Satellite L45-S7423 Wireless Card Replacement: étape 2, image 2 de 2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Wireless Card Replacement: étape 3, image 1 de 2 Toshiba Satellite L45-S7423 Wireless Card Replacement: étape 3, image 2 de 2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Wireless Card Replacement, Bottom Access Panel: étape 4, image 1 de 3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Bottom Access Panel: étape 4, image 2 de 3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Bottom Access Panel: étape 4, image 3 de 3
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  5. Toshiba Satellite L45-S7423 Wireless Card Replacement: étape 5, image 1 de 3 Toshiba Satellite L45-S7423 Wireless Card Replacement: étape 5, image 2 de 3 Toshiba Satellite L45-S7423 Wireless Card Replacement: étape 5, image 3 de 3
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  6. Toshiba Satellite L45-S7423 Wireless Card Replacement, Wireless Card: étape 6, image 1 de 3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Wireless Card: étape 6, image 2 de 3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Wireless Card: étape 6, image 3 de 3
    • Remove the black and the white antenna wires attached to the wireless card.
    • Using a plastic removal tool, gently pop the connections apart.
  7. Toshiba Satellite L45-S7423 Wireless Card Replacement: étape 7, image 1 de 2 Toshiba Satellite L45-S7423 Wireless Card Replacement: étape 7, image 2 de 2
    • Remove the screws holding the wireless card in place.
    • Two 3.6 mm Phillips screws.
  8. Toshiba Satellite L45-S7423 Wireless Card Replacement: étape 8, image 1 de 1
    • The wireless card will automatically pop up allowing for easy removal.
  9. Toshiba Satellite L45-S7423 Wireless Card Replacement: étape 9, image 1 de 2 Toshiba Satellite L45-S7423 Wireless Card Replacement: étape 9, image 2 de 2
    • Pull to remove the wireless card.
2 autres ont terminé cette réparation.
Stephen Sippel
Membre depuis le 04/16/13
194 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 21-54, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
4 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 2,302
