Aller au contenu principal
Toshiba Satellite L455-S5975 Hard Drive Replacement
Mike Kennedy
Mike Kennedy et 7 autres contributeurs
Dernière mise à jour le July 16, 2014
10 minutes
Facile
This guide is useful for replacing a broken hard drive on your laptop. All of your computer's important data is stored on the hard drive. In this replacement guide, you will remove the hard drive cover to access the hard drive.
Note: Before starting any removal or installation, remember to turn off the device and to remove it from the power source.
Ce dont vous avez besoin
Outils
  1. Toshiba Satellite L455-S5975 Hard Drive Replacement, Hard Drive: étape 1, image 1 de 1
    • Remove the two 7 mm screws with a Phillips#00 Screwdriver
  2. Toshiba Satellite L455-S5975 Hard Drive Replacement: étape 2, image 1 de 1
    • Using a flat head from a plastic opening tool to lift open the cover.
  3. Toshiba Satellite L455-S5975 Hard Drive Replacement: étape 3, image 1 de 1
    • Remove the four 6mm screws with the Phillips #00 screwdriver.
  4. Toshiba Satellite L455-S5975 Hard Drive Replacement: étape 4, image 1 de 1
    • Pull out black tab located on the hard drive to slide it out.
Mike Kennedy
Membre depuis le 04/18/13
160 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 2-21, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 2-21, Maness Spring 2013
CPSU-MANESS-S13S2G21
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 5
Total : 3,536
