Aller au contenu principal
Toshiba Satellite L755-S5244 RAM Replacement
Carter Willson
Carter Willson et 2 autres contributeurs
Dernière mise à jour le June 14, 2019
4 - 6 minutes
Facile
If your computer has become very slow, crashed frequently, or you simply do not have enough RAM to run a program, this guide will show you how to access and replace RAM sticks.
Ce dont vous avez besoin
Outils
  1. Toshiba Satellite L755-S5244 RAM Replacement, RAM: étape 1, image 1 de 2 Toshiba Satellite L755-S5244 RAM Replacement, RAM: étape 1, image 2 de 2
    • Loosen the two 3mm Phillips #0 screws securing the hard drive panel. The panel will retain the screws, so do not remove them completely.
    • Remove the panel from the laptop (the hard drive does not need to be removed).
  2. Toshiba Satellite L755-S5244 RAM Replacement: étape 2, image 1 de 2 Toshiba Satellite L755-S5244 RAM Replacement: étape 2, image 2 de 2
    • Loosen the three 3mm Phillips #0 screws that secure the center panel. The screws are retained by the cover, so do not remove them completely.
    • Remove the panel by pulling out to the right.
    • The two RAM sticks are stacked, one on top of the other.
  3. Toshiba Satellite L755-S5244 RAM Replacement: étape 3, image 1 de 2 Toshiba Satellite L755-S5244 RAM Replacement: étape 3, image 2 de 2
    • Each RAM stick has two (2) snap locks, one on each end. In the image the bottom snap is obscured by the cable.
  4. Toshiba Satellite L755-S5244 RAM Replacement: étape 4, image 1 de 1
    • Move the retaining clips out of their locking position, allowing the RAM stick to pop up.
    • Lift the free end of the RAM stick until the stick can be freely removed from its slot.
  5. Toshiba Satellite L755-S5244 RAM Replacement: étape 5, image 1 de 1
    • The RAM stick has a notch that is not centered on the stick. Be sure to take note of the RAM stick's orientation for reinstallation
  6. Toshiba Satellite L755-S5244 RAM Replacement: étape 6, image 1 de 1
    • Repeat for the second RAM stick.
Carter Willson
Membre depuis le 04/15/19
248 Réputation
2 tutoriels rédigés
Un commentaire
Nice article, Carter.
Parenthetically, we hoped to find the maximum RAM capacity, as well,
but that is not directly related to the process you illustrate.
Bob Greene - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 386
