Aller au contenu principal
Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement
Michael Griskewicz
Michael Griskewicz et 6 autres contributeurs
Dernière mise à jour le December 28, 2016
15 - 45 minutes
Modérée
Usually if your Optical Disc Drive(ODD) needs to be replaced it means that your disks aren't being read, a noisy sound from the ODD, or maybe it just isn't taking the disk. It's good to make sure your computer's software is updated before you replace the ODD. As this can sometime solve your issue.
Ce dont vous avez besoin
Outils
  1. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Battery: étape 1, image 2 de 2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Keyboard: étape 2, image 1 de 1
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: étape 3, image 1 de 1
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: étape 4, image 1 de 1
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
  5. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Optical Disc Drive: étape 5, image 1 de 1
    • Use the screwdiver and the Phillips PH00 to unscrew the three, 4mm screws for the RAM compartment
  6. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: étape 6, image 1 de 2 Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: étape 6, image 2 de 2
    • Use the Phillips PH00 to remove the 4mm screw that holds the ODD.
    • Slide the ODD outward.
  7. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: étape 7, image 1 de 1
    • Remove the two 4mm screws and the plate attached to the ODD.
Michael Griskewicz
Membre depuis le 10/06/16
159 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 2-5, Sullivan Fall 2016 Membre de l'équipe USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 357
