Toshiba Satellite L755D-S5150 RAM Replacement
Introduction
Passez à l'étape 1Follow this guide if you need to replace or upgrade your RAM. Sometimes people want to upgrade their RAM rather than replace it because the RAM helps your computer read data faster.
Ce dont vous avez besoin
Outils
After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
Using the Phillips PH00 screwdriver unscrew the three 4mm screws for the cover of the Ram compartment.
Now remove the cover for the Ram compartment.
