Aller au contenu principal
Toshiba Satellite M35X-S114 RAM Replacement
Christian Mayorga
Christian Mayorga et 3 autres contributeurs
Dernière mise à jour le January 6, 2015
5 - 10 minutes
Modérée
Accessing the RAM of the laptop involves removing a screw in order to open an access hatch on the bottom of the laptop. Once opened, the RAM sticks can be unplugged from their slots once released from the metal prongs holding them in place.
Larger capacity RAM sticks can be purchased from most online computer hardware retailers, though you may need to find specific RAM sticks that are compatible with the laptops model. RAM sticks used in laptops are made smaller than typical RAM sticks in order to fit within the laptop's compact size.
Ce dont vous avez besoin
Outils
  1. Toshiba Satellite M35X-S114 RAM Replacement, Unlock the Battery from its Compartment: étape 1, image 1 de 2 Toshiba Satellite M35X-S114 RAM Replacement, Unlock the Battery from its Compartment: étape 1, image 2 de 2
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 RAM Replacement, Move the Battery's Release Switch: étape 2, image 1 de 2 Toshiba Satellite M35X-S114 RAM Replacement, Move the Battery's Release Switch: étape 2, image 2 de 2
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 RAM Replacement, Remove the Battery: étape 3, image 1 de 2 Toshiba Satellite M35X-S114 RAM Replacement, Remove the Battery: étape 3, image 2 de 2
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
  4. Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: étape 4, image 1 de 3 Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: étape 4, image 2 de 3 Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: étape 4, image 3 de 3
    • Locate the RAM cover around the middle left-hand side of the device.
    • Locate the screw on the RAM cover.
    • Use a Phillips 00 screwdriver to remove the 7.50mm screw.
    • Carefully remove the RAM access hatch.
  5. Toshiba Satellite M35X-S114 RAM Replacement, Remove the RAM sticks.: étape 5, image 1 de 2 Toshiba Satellite M35X-S114 RAM Replacement, Remove the RAM sticks.: étape 5, image 2 de 2
    • Locate the four silver clips holding the RAM sticks.
    • There is a total of two RAM chips and four silver clips. Two silver clips hold one RAM stick. Remove one RAM stick at a time.
    • Use your fingers from separate hands to pull back the two silver clips away from the sides of the RAM stick.
    • Repeat this step for the other RAM stick.
  6. Toshiba Satellite M35X-S114 RAM Replacement: étape 6, image 1 de 1
    • Gently pull the RAM stick out from its slot.
Christian Mayorga
Membre depuis le 09/09/14
219 Réputation
2 tutoriels rédigés
Équipe
CSU Fullerton, Team 2-4, Bruce Fall 2014 Membre de l'équipe CSU Fullerton, Team 2-4, Bruce Fall 2014
CSUF-BRUCE-F14S2G4
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 4
Total : 457
