Toshiba Satellite M55-S135 Battery Replacement
Introduction
Passez à l'étape 1This guide will be referred to for other steps because disconnecting the power to your computer is crucial to do before working on it. Two spring-loaded switches lock the Toshiba Satellite M55-S135 battery into place.
Orient the laptop so that it is closed, faced down, and the battery is facing away from you.
Slide the unlock switch in the top left-hand corner to the left/unlock position.
