Aller au contenu principal
Toshiba Satellite P50W-C Hard Drive Replacement
Sarah Fordjour
Sarah Fordjour et 2 autres contributeurs
Dernière mise à jour le December 13, 2017
4 - 7 minutes
Facile
Be careful to handle this device with care while performing this guide make sure to use use an anti-static wrist strap.
Ce dont vous avez besoin
Outils
  1. Toshiba Satellite P50W-C Hard Drive Replacement, Back Cover: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Hard Drive Replacement: étape 2, image 1 de 1
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Hard Drive Replacement: étape 3, image 1 de 2 Toshiba Satellite P50W-C Hard Drive Replacement: étape 3, image 2 de 2
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Hard Drive Replacement, Hard Drive: étape 4, image 1 de 1
    • Remove the back cover of the device.
  5. Toshiba Satellite P50W-C Hard Drive Replacement: étape 5, image 1 de 1
    • Remove the hard drive from the device by gently pulling on the blue plastic hard drive cover.
  6. Toshiba Satellite P50W-C Hard Drive Replacement: étape 6, image 1 de 2 Toshiba Satellite P50W-C Hard Drive Replacement: étape 6, image 2 de 2
    • Disconnect the hard drive from the mother board by gently pulling out the black connector.
2 autres ont terminé cette réparation.
Sarah Fordjour
Membre depuis le 09/25/17
450 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S3-G2, Cannon Fall 2017 Membre de l'équipe USF Tampa, Team S3-G2, Cannon Fall 2017
USFT-CANNON-F17S3G2
4 membres
7 tutoriels rédigés
2 commentaires
Can you change the touch panel of toshibasatelliteP50W-B1038.
rizwana rizi - Réponse
Hi dear,
My laptop bios was crashed,
I need to radius 15 p50w-c-104 bios dump file.
can you help me please.?
labexperiance@gmail.com
thank you
Mustafa SAYIN - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 705
