Aller au contenu principal
Toshiba Satellite P55W-C5316 Fan Replacement
Zeyad Ali
Zeyad Ali et 4 autres contributeurs
Dernière mise à jour le August 1, 2024
15 minutes
Facile
A besoin de meilleures images
Nécessite plus d'images
The fan in a laptop keeps the device cool and from overheating. If your Toshiba Satellite P55W-C5316 starts to overheat, other components in your device may start to fail. In addition, you may experience that your device is running slower than normal. If your device is overheating and if your fan is making loud noises, it is time to replace the fan in your device. Follow these instructions to remove the fan from your Toshiba Satellite P55W-C5316 laptop.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Toshiba Satellite P55W-C5316 Fan Replacement, Back Panel: étape 1, image 1 de 2 Toshiba Satellite P55W-C5316 Fan Replacement, Back Panel: étape 1, image 2 de 2
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Fan Replacement: étape 2, image 1 de 3 Toshiba Satellite P55W-C5316 Fan Replacement: étape 2, image 2 de 3 Toshiba Satellite P55W-C5316 Fan Replacement: étape 2, image 3 de 3
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
  3. Toshiba Satellite P55W-C5316 Fan Replacement, Fan: étape 3, image 1 de 1
    • Remove both screws from the fan.
  4. Toshiba Satellite P55W-C5316 Fan Replacement: étape 4, image 1 de 2 Toshiba Satellite P55W-C5316 Fan Replacement: étape 4, image 2 de 2
    • Remove the screws securing the 4 corners of the heatsink.
    • Gently remove the heatsink. Keep in mind thermal paste is used and it may be slightly difficult to remove.
  5. Toshiba Satellite P55W-C5316 Fan Replacement: étape 5, image 1 de 3 Toshiba Satellite P55W-C5316 Fan Replacement: étape 5, image 2 de 3 Toshiba Satellite P55W-C5316 Fan Replacement: étape 5, image 3 de 3
    • Remove the small, beige colored connector securing the fan to the laptop and remove the fan and heatsink assembly from the laptop.
Zeyad Ali
Membre depuis le 11/07/19
349 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S2-G1, Harley Fall 2019 Membre de l'équipe IUPUI, Team S2-G1, Harley Fall 2019
IUPUI-HARLEY-F19S2G1
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 429
