Aller au contenu principal
Toshiba Satellite P55t-A5116 Battery Replacement
Brittany Castillo
Brittany Castillo et 4 autres contributeurs
Dernière mise à jour le October 21, 2022
2 minutes
Modérée
Use this guide to remove the Toshiba Satellite P55t-A5116 battery.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Toshiba Satellite P55t-A5116 Battery Replacement, Back Casing: étape 1, image 1 de 2 Toshiba Satellite P55t-A5116 Battery Replacement, Back Casing: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    • Close laptop and turn it upside down
    • Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
  2. Toshiba Satellite P55t-A5116 Battery Replacement: étape 2, image 1 de 2 Toshiba Satellite P55t-A5116 Battery Replacement: étape 2, image 2 de 2
    • Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
  3. Toshiba Satellite P55t-A5116 Battery Replacement: étape 3, image 1 de 3 Toshiba Satellite P55t-A5116 Battery Replacement: étape 3, image 2 de 3 Toshiba Satellite P55t-A5116 Battery Replacement: étape 3, image 3 de 3
    • Gently pry off the bottom case with the plastic opening tools.
    • Find the seam between the back case and the rest of the laptop casing.
  4. Toshiba Satellite P55t-A5116 Battery Replacement, Battery: étape 4, image 1 de 2 Toshiba Satellite P55t-A5116 Battery Replacement, Battery: étape 4, image 2 de 2
    • Use the #PH0 screw head, remove 4 (5.7mm) screws.
    • Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
  5. Toshiba Satellite P55t-A5116 Battery Replacement: étape 5, image 1 de 1
    • Gently remove battery from the laptop.
12 autres ont terminé cette réparation.
Brittany Castillo
Membre depuis le 01/19/17
878 Réputation
5 tutoriels rédigés
9 commentaires
The screws for the battery are in very tight and I'm having trouble unscrewing them
Brianna Brucale - Réponse
I'm having difficulty unplugging the 10 pin connector. Afraid if I pull too hard it will pull the wires out. Any suggestions?
jmomenee - Réponse
Just wiggle it back-and-forth a bit and it should come out. I just change my own battery.
Carmen Cuevas -
I did all of that but my laptop didn’t reboot, any suggestions
roberta - Réponse
I had no problem installing the new battery, but even after letting it charge over 24 hours. Not able to get it to turn on
roberta - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 15
30 derniers jours : 34
Total : 23,022
