Aller au contenu principal
Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement
Jacob Volcke
Jacob Volcke et 3 autres contributeurs
Dernière mise à jour le January 21, 2025
30 - 50 minutes
Modérée
Nécessite plus d'images
Étapes manquantes
Texte bizarre
Problème de balise
Meilleure introduction
This guide will show you how to replace the speaker of your Toshiba Satellite P755-EZ1511D laptop.
  1. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement, Battery: étape 1, image 1 de 1
    • First flip the device over so that the back side is facing upwards
  2. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 2, image 1 de 1
    • Push the two sliders toward the edge of the laptop.
    • Remove the battery.
  3. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement, Hard Drive: étape 3, image 1 de 1
    • First, remove the screw holding the hard drive cover in place.
  4. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 4, image 1 de 3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 4, image 2 de 3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 4, image 3 de 3
    • Lift the cover and set it aside.
  5. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 5, image 1 de 1
    • Remove the hard drive.
  6. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement, Speakers: étape 6, image 1 de 3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement, Speakers: étape 6, image 2 de 3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement, Speakers: étape 6, image 3 de 3
    • Remove all of the screws labeled F8 from the backside of the device.
  7. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 7, image 1 de 3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 7, image 2 de 3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 7, image 3 de 3
    • Flip the device over and open it up.
    • Using your pry tool begin to pop the keyboard upwards starting from the side closest to the screen. You will hear an audible "pop" sound.
  8. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 8, image 1 de 3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 8, image 2 de 3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 8, image 3 de 3
    • After popping the keyboard off you need to disconnect the keyboard from the motherboard.
  9. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 9, image 1 de 2 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 9, image 2 de 2
    • Remove the two screws labeled F8 in the shown places.
  10. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 10, image 1 de 1
    • Remove the optical drive from the device. Just pull it out.
  11. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 11, image 1 de 2 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 11, image 2 de 2
    • The next step is to unplug the speakers from the motherboard. The wire shown is the speaker wire.
  12. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 12, image 1 de 3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 12, image 2 de 3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 12, image 3 de 3
    • Next, take your pry tool again and start to lift around the edge of the device. Once you get it lifted enough, use your hands to pop the top panel of the base of the device.
  13. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 13, image 1 de 2 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 13, image 2 de 2
    • Next, remove the wires from the the small clips holding them in place.
  14. Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 14, image 1 de 3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 14, image 2 de 3 Toshiba Satellite P755-EZ1511D Laptop Speakers Replacement: étape 14, image 3 de 3
    • Lastly, remove the two screws holding the speaker in place.
    • After doing that you will be able to just lift up on the speaker to remove it.
    • Repeat Steps 8 and 9 for the other speaker.
Jacob Volcke
Membre depuis le 09/22/22
665 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 10
Total : 298
