Aller au contenu principal
Toshiba Satellite P855-S5102 RAM Replacement
Benson Smith
Benson Smith et 3 autres contributeurs
Dernière mise à jour le July 23, 2018
Aucune estimation
Modérée
The RAM card is the part of the computer that has memory and stores the data being used by the computer. It keeps the computer's functions regulating smoothly. Below are a few steps to take in order to remove and replace the computer's RAM Cards.
Ce dont vous avez besoin
Outils
  1. Toshiba Satellite P855-S5102 RAM Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite P855-S5102 RAM Replacement, Battery: étape 1, image 2 de 2
    • Push the locking tabs away from each other.
  2. Toshiba Satellite P855-S5102 RAM Replacement: étape 2, image 1 de 2 Toshiba Satellite P855-S5102 RAM Replacement: étape 2, image 2 de 2
    • Pull up on the battery to remove.
  3. Toshiba Satellite P855-S5102 RAM Replacement, RAM: étape 3, image 1 de 2 Toshiba Satellite P855-S5102 RAM Replacement, RAM: étape 3, image 2 de 2
    • Remove the 3mm Phillips #0 screw from the cover.
  4. Toshiba Satellite P855-S5102 RAM Replacement: étape 4, image 1 de 3 Toshiba Satellite P855-S5102 RAM Replacement: étape 4, image 2 de 3 Toshiba Satellite P855-S5102 RAM Replacement: étape 4, image 3 de 3
    • Use a plastic opening tool to lift up the cover and remove by hand.
  5. Toshiba Satellite P855-S5102 RAM Replacement: étape 5, image 1 de 3 Toshiba Satellite P855-S5102 RAM Replacement: étape 5, image 2 de 3 Toshiba Satellite P855-S5102 RAM Replacement: étape 5, image 3 de 3
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
Lift the RAM module to an angle of about 30 degrees and slide it out.
Benson Smith
Membre depuis le 01/25/18
351 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S20-G3, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S20-G3, Passmore Spring 2018
USFT-PASSMORE-S18S20G3
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 366
