Aller au contenu principal
Toshiba Satellite P855-S5312 Screen Replacement
Bishop Clark
Bishop Clark et 4 autres contributeurs
Dernière mise à jour le May 7, 2024
40 - 45 minutes
Modérée
This guide will explain how to replace the screen on the Toshiba Satellite P855-S5312. Reasons for replacement include black or spotty screen images. The screen is a very fragile component of the device. It requires a small plastic prying tool and a small screwdriver.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Toshiba Satellite P855-S5312 Screen Replacement, Fan: étape 1, image 1 de 3 Toshiba Satellite P855-S5312 Screen Replacement, Fan: étape 1, image 2 de 3 Toshiba Satellite P855-S5312 Screen Replacement, Fan: étape 1, image 3 de 3
    • Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
    • Pry up the panel to gain access to hidden screws.
  2. Toshiba Satellite P855-S5312 Screen Replacement: étape 2, image 1 de 2 Toshiba Satellite P855-S5312 Screen Replacement: étape 2, image 2 de 2
    • Remove the fourteen (14) screws using a Philips #0 screwdriver for the 1.5mm screws on the underside of casing.
  3. Toshiba Satellite P855-S5312 Screen Replacement: étape 3, image 1 de 3 Toshiba Satellite P855-S5312 Screen Replacement: étape 3, image 2 de 3 Toshiba Satellite P855-S5312 Screen Replacement: étape 3, image 3 de 3
    • Unscrew the nine 1.5mm screws using a Philips #0 screwdriver under the keyboard with the F6 printed next to them.
    • Unplug the three no-fuss ribbon cable connector cables by gently pulling on them away from you towards the keyboard.
  4. Toshiba Satellite P855-S5312 Screen Replacement: étape 4, image 1 de 2 Toshiba Satellite P855-S5312 Screen Replacement: étape 4, image 2 de 2
    • Pry apart the casing with the plastic opening tool.
    • Removing the cover under keyboard.
  5. Toshiba Satellite P855-S5312 Screen Replacement: étape 5, image 1 de 3 Toshiba Satellite P855-S5312 Screen Replacement: étape 5, image 2 de 3 Toshiba Satellite P855-S5312 Screen Replacement: étape 5, image 3 de 3
    • Unplug the single no-fuss cable connector using the plastic opening tool pushing the edges towards the fan.
    • Unscrew the two 1.5mm screws using a Philips #0 screwdriver by the head mounting holding down the fan.
    • Pull the fan up and remove it from the device.
  6. Toshiba Satellite P855-S5312 Screen Replacement, Screen: étape 6, image 1 de 3 Toshiba Satellite P855-S5312 Screen Replacement, Screen: étape 6, image 2 de 3 Toshiba Satellite P855-S5312 Screen Replacement, Screen: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    • Turn laptop upside down with the spine facing towards you and locate the microchip.
    • Remove the white and black sliding connector wires by prying upward with tweezers gently pulling the black and white wires upwards.
  7. Toshiba Satellite P855-S5312 Screen Replacement: étape 7, image 1 de 2 Toshiba Satellite P855-S5312 Screen Replacement: étape 7, image 2 de 2
    • Unplug the single ZIF connector ribbon by gently pulling up.
    • Pull the white and black wires through from the underside of device.
  8. Toshiba Satellite P855-S5312 Screen Replacement: étape 8, image 1 de 3 Toshiba Satellite P855-S5312 Screen Replacement: étape 8, image 2 de 3 Toshiba Satellite P855-S5312 Screen Replacement: étape 8, image 3 de 3
    • Unscrew the four hinges mounting the 1.5mm screws on each side from casing using a Philips #0 screwdriver.
    • Remove entire screen assembly from casing.
  9. Toshiba Satellite P855-S5312 Screen Replacement: étape 9, image 1 de 3 Toshiba Satellite P855-S5312 Screen Replacement: étape 9, image 2 de 3 Toshiba Satellite P855-S5312 Screen Replacement: étape 9, image 3 de 3
    • Locate the two black sticker covers on the bottom of both sides of the monitor
    • Using a pair of tweezers, carefully remove black stickers concealing two screws
  10. Toshiba Satellite P855-S5312 Screen Replacement: étape 10, image 1 de 3 Toshiba Satellite P855-S5312 Screen Replacement: étape 10, image 2 de 3 Toshiba Satellite P855-S5312 Screen Replacement: étape 10, image 3 de 3
    • Using a prying tool, carefully pry along the edges of the screen cover
  11. Toshiba Satellite P855-S5312 Screen Replacement: étape 11, image 1 de 2 Toshiba Satellite P855-S5312 Screen Replacement: étape 11, image 2 de 2
    • Unscrew the two 1.5mm screws at the bottom of monitor using a Philips #0 screwdriver.
  12. Toshiba Satellite P855-S5312 Screen Replacement: étape 12, image 1 de 3 Toshiba Satellite P855-S5312 Screen Replacement: étape 12, image 2 de 3 Toshiba Satellite P855-S5312 Screen Replacement: étape 12, image 3 de 3
    • With all the edges of the screen cover pried up, carefully remove the screen cover.
  13. Toshiba Satellite P855-S5312 Screen Replacement: étape 13, image 1 de 3 Toshiba Satellite P855-S5312 Screen Replacement: étape 13, image 2 de 3 Toshiba Satellite P855-S5312 Screen Replacement: étape 13, image 3 de 3
    • Using the Philips #0 screwdriver, remove the four 1.5mm screws at the corners of the screen.
  14. Toshiba Satellite P855-S5312 Screen Replacement: étape 14, image 1 de 3 Toshiba Satellite P855-S5312 Screen Replacement: étape 14, image 2 de 3 Toshiba Satellite P855-S5312 Screen Replacement: étape 14, image 3 de 3
    • At the top of the screen, using the tweezers, remove the ZIF ribbon connector by gently pushing it up.
  15. Toshiba Satellite P855-S5312 Screen Replacement: étape 15, image 1 de 2 Toshiba Satellite P855-S5312 Screen Replacement: étape 15, image 2 de 2
    • Remove the screen from the device.
    • Make sure to be carful because the screen is very fragile.
Bishop Clark
Membre depuis le 10/02/17
225 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S10-G2, Thompson Fall 2017 Membre de l'équipe USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 787
