Aller au contenu principal
Toshiba Satellite S50-B Hard Drive Replacement
Victoria Murillo
Victoria Murillo et 6 autres contributeurs
Dernière mise à jour le January 22, 2020
8 minutes
Modérée
This guide details how to replace the hard drive of a Toshiba Satellite S50-B laptop. You will need a Phillips 0 screwdriver and a plastic opening tool for this replacement.
Ce dont vous avez besoin
Kits de réparation
Ces kits contiennent toutes les pièces et tous les outils nécessaires à la réalisation du tutoriel.
Pièces
Outils
Afficher plus…
  1. Toshiba Satellite S50-B Hard Drive Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite S50-B Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Make sure you turn off the laptop first.
    • Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
  2. Toshiba Satellite S50-B Hard Drive Replacement: étape 2, image 1 de 2 Toshiba Satellite S50-B Hard Drive Replacement: étape 2, image 2 de 2
    • Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
  3. Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: étape 3, image 1 de 3 Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: étape 3, image 2 de 3 Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: étape 3, image 3 de 3
    • Locate the 12 screws on the bottom of the device. Unscrew using a Phillips screwdriver, and set screws aside.
    • Use a plastic opening tool to remove bottom casing.
  4. Toshiba Satellite S50-B Hard Drive Replacement: étape 4, image 1 de 2 Toshiba Satellite S50-B Hard Drive Replacement: étape 4, image 2 de 2
    • Use the plastic casing over the hard drive to lift the hard drive up.
    • Once hard drive is slightly lifted up, make sure the laptop is in correct orientation with the battery away from you, and pull the hard drive towards right.
4 autres ont terminé cette réparation.
Victoria Murillo
Membre depuis le 10/17/17
143 Réputation
1 tutoriel rédigé
Équipe
UC Santa Barbara, Team S1-G4, Weedon Fall 2017 Membre de l'équipe UC Santa Barbara, Team S1-G4, Weedon Fall 2017
UCSB-WEEDON-F17S1G4
5 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 18
Total : 6,222
