Aller au contenu principal
Toshiba Satellite T135D-S1324 Battery Replacement
Karin Juarez
Karin Juarez et 2 autres contributeurs
Dernière mise à jour le June 18, 2019
4 minutes
Très facile
This guide will be very useful if you are facing problems with turning on your device.
If you are having trouble turning on your Toshiba Satellite T135D-S1324 you might want to replace the battery. By replacing the main source of energy you should find that your laptop will light up and you should be able to get back to work in a matter of minutes.
  1. Toshiba Satellite T135D-S1324 Battery Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite T135D-S1324 Battery Replacement, Battery: étape 1, image 2 de 2
    • Make sure to turn off your device and unplug it before you proceed.
    • Pull back the claps to release the battery.
    • When the battery is unlocked, pull back the battery to completely remove it.
Karin Juarez
Membre depuis le 02/04/19
73 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team S1-G3, Saknee Spring 2019 Membre de l'équipe Gateway, Team S1-G3, Saknee Spring 2019
GCC-SAKNEE-S19S1G3
4 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 235
