Aller au contenu principal
Toshiba Satellite U925T-S2120 Hard Drive Replacement
Terry
Terry et 6 autres contributeurs
Dernière mise à jour le May 7, 2024
15 - 20 minutes
Facile
Your hard drive stores and retrieves all memory on your laptop. In this guide you will learn how to remove the hard drive of your Toshiba Satellite U925T-S2120. If your hard drive is broken, you may need to replace it. Prior to beginning this guide you should have all required tools that are listed.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Toshiba Satellite U925T-S2120 Hard Drive Replacement, Hard Drive: étape 1, image 1 de 2 Toshiba Satellite U925T-S2120 Hard Drive Replacement, Hard Drive: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    • Use tweezers to pinch and pull out and remove the nine rubber gripper pads on the back panel of the laptop. Set aside.
  2. Toshiba Satellite U925T-S2120 Hard Drive Replacement: étape 2, image 1 de 3 Toshiba Satellite U925T-S2120 Hard Drive Replacement: étape 2, image 2 de 3 Toshiba Satellite U925T-S2120 Hard Drive Replacement: étape 2, image 3 de 3
    • Unscrew nine 5.8 mm screws using a PH1 screwdriver and turning clockwise.
    • Use the same screwdriver to remove the two 6.8 mm screws.
  3. Toshiba Satellite U925T-S2120 Hard Drive Replacement: étape 3, image 1 de 2 Toshiba Satellite U925T-S2120 Hard Drive Replacement: étape 3, image 2 de 2
    • Remove the back panel open by inserting the plastic opening tool into the seam of the laptop and pushing downwards. Repeat the motion around the perimeter of the device.
  4. Toshiba Satellite U925T-S2120 Hard Drive Replacement: étape 4, image 1 de 1
    • Gently pop out the tab connected to the orange plastic strip.
  5. Toshiba Satellite U925T-S2120 Hard Drive Replacement: étape 5, image 1 de 1
    • Hold back the orange plastic strip with one hand
    • Use a PH1 screwdriver to unscrew the two 3.4 mm screws by turning clockwise.
  6. Toshiba Satellite U925T-S2120 Hard Drive Replacement: étape 6, image 1 de 1
    • Lift the silver flap away from the hard drive.
    • Gently pinch and lift out the hard drive with your thumb and pointer finger.
  7. Toshiba Satellite U925T-S2120 Hard Drive Replacement: étape 7, image 1 de 1
    • Completely remove the hard drive from the device.
2 autres ont terminé cette réparation.
Terry
Membre depuis le 03/29/17
137 Réputation
1 tutoriel rédigé
Équipe
Baylor, Team S5-G5, Williams Spring 2017 Membre de l'équipe Baylor, Team S5-G5, Williams Spring 2017
BU-WILLIAMS-S17S5G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 5
Total : 1,902
