Aller au contenu principal
UDI U818A Camera Assembly Replacement
Anthony Mitchell
Anthony Mitchell et 9 autres contributeurs
Dernière mise à jour le January 9, 2020
1 - 2 heures
Modérée
Replacing the camera assembly of the UDI U818A drone requires complete disassembly. The main frame is attached to the receiving board on the very inside of the drone. You will separate these two parts by unscrewing the screws in all four corners.
You should replace the camera of the drone if you notice a blurry image being received from the drone and have already troubleshoot connectivity issues, or if there is no image present at all.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. UDI U818A Camera Assembly Replacement, Propellers: étape 1, image 1 de 2 UDI U818A Camera Assembly Replacement, Propellers: étape 1, image 2 de 2
    • Remove the 5 mm screws connecting each propeller to the rotating post using a Phillips #000 screwdriver.
    • As each screw is removed, safely pull the respective propeller from its apparatus.
  2. UDI U818A Camera Assembly Replacement, Drone Cover: étape 2, image 1 de 2 UDI U818A Camera Assembly Replacement, Drone Cover: étape 2, image 2 de 2
    • Remove four 3 mm screws connecting the electronics to the frame using a Phillips #000 screwdriver.
    • Pull the two LED bars through the dust cover and remove the thin plastic dust cover from the drone.
    • As the piece connecting the electronics to the drone cover are accessible, keep note to not remove electronics until after disconnecting the drone head lamp first.
  3. UDI U818A Camera Assembly Replacement: étape 3, image 1 de 2 UDI U818A Camera Assembly Replacement: étape 3, image 2 de 2
    • Remove the single 5 mm screw from the head lamp using a Phillips #000 screwdriver.
    • Remove the head lamp from the rest of the drone.
    • Disconnect the electronics from the frame of the drone by pulling each arm out of the hole in the frame holding it in place.
    • Do not try to separate the frame from the electronics yet! Check to see if there is tape holding the head lamp wires in place underneath the electronics.
  4. UDI U818A Camera Assembly Replacement: étape 4, image 1 de 3 UDI U818A Camera Assembly Replacement: étape 4, image 2 de 3 UDI U818A Camera Assembly Replacement: étape 4, image 3 de 3
    • If present, remove the white tape over the black and red wires on the head lamp with a spudger.
    • Keep the tape in reusable condition to re-secure the headlight later so there are no loose wires.
    • Separate the plastic tabs securing the motor arms to the drone cover and delicately pull out the arm. Do this for all four arms to remove the frame from the cover.
  5. UDI U818A Camera Assembly Replacement, Drone Arms: étape 5, image 1 de 1
    • Remove four 5 mm corner screws that secure both the receiving board and the motor arm using a Phillips #000 screwdriver.
    • When reassembling, notice how the wires tuck neatly in the bottom channel of the motor arm.
  6. UDI U818A Camera Assembly Replacement: étape 6, image 1 de 3 UDI U818A Camera Assembly Replacement: étape 6, image 2 de 3 UDI U818A Camera Assembly Replacement: étape 6, image 3 de 3
    • Carefully slide the arm out from the socket.
    • Use a nylon spudger to remove the connectors from the receiving board.
    • The cables connecting to the receiving board will be secured with a light adhesive that can be easily scraped away to remove the desired connector.
  7. UDI U818A Camera Assembly Replacement: étape 7, image 1 de 2 UDI U818A Camera Assembly Replacement: étape 7, image 2 de 2
    • Motor direction and propeller direction is crucial to proper flight. Refer to this format when reassembling.
    • The Front Left motor identified by the Red/Blue wires is a Standard(Clockwise) spinning motor, it pairs with a White A2 propeller.
    • The Front Right motor identified by the Black/White wires is a Reverse(CounterClockwise) spinning motor, it pairs with a White B2 propeller.
    • The Back Left motor identified by the Black/White wires is a Reverse(CounterClockwise) spinning motor, it pairs with a Black B1 propeller.
    • The Back Right motor identified by the Red/Blue wires is a Standard(Clockwise) spinning motor, it pairs with a Black A1 propeller.
  8. UDI U818A Camera Assembly Replacement: étape 8, image 1 de 1
    • The wiring can appear confusing, don't be alarmed. It's quite easy, and absolutely necessary for proper flight.
    • The 4 bottom connectors receive the motor power cables that are Red/Yellow wire pairs from each motor. Counting the sockets 1-4 from left to right.
    • Front Right motor connects to socket 1.
    • Front Left motor connects to socket 2.
    • Rear Left motor connects to socket 3.
    • Rear Right motor connects to socket 4.
    • The Red/Green wire pairs from each motor power the LED to that branch, they connect to 4 of 6 sockets on the top of the receiving board. There is no sequence required.
    • The headlight LED, and underside LED bars connect to the remaining 2 sockets on the top of the receiving board. Again, no sequence is required. All LED Red/Black and Red/Green wire pairs connect to top of the receiving board.
  9. UDI U818A Camera Assembly Replacement, Camera Assembly: étape 9, image 1 de 2 UDI U818A Camera Assembly Replacement, Camera Assembly: étape 9, image 2 de 2
    • Use a spudger to unplug the camera cable from the processing chip.
  10. UDI U818A Camera Assembly Replacement: étape 10, image 1 de 2 UDI U818A Camera Assembly Replacement: étape 10, image 2 de 2
    • Take out all four of the 5mm screws from the main frame using a Phillips #000 screwdriver.
    • Once all four screws are removed, carefully separate the main frame from the camera.
Reassemble the device by following these instructions in reverse order.
2 autres ont terminé cette réparation.
Anthony Mitchell
Membre depuis le 03/23/16
838 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-4, Miles Spring 2016 Membre de l'équipe UMass Dartmouth, Team 1-4, Miles Spring 2016
UMASSD-MILES-S16S1G4
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 12
Total : 2,029
