Aller au contenu principal
VooDooQuad  250 Propeller Replacement
Damir Pamic
Damir Pamic et un autre contributeur
Dernière mise à jour le June 5, 2017
5 minutes
Très facile
Chipping or breaking of a propeller for any level drone flier is inevitable. It is an incredibly common troubleshoot, but luckily a simple replacement. Make sure you have a clean working station, and all you'll need is a set of pliers to put on the new set.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. VooDooQuad  250 Propeller Replacement, Propeller: étape 1, image 1 de 2 VooDooQuad  250 Propeller Replacement, Propeller: étape 1, image 2 de 2
    • Unplug the power cable of the drone to eliminate unnecessary mishaps.
  2. VooDooQuad  250 Propeller Replacement: étape 2, image 1 de 1
    • With your set of pliers loosen and remove the four bolts holding the propellers to the motor.
  3. VooDooQuad  250 Propeller Replacement: étape 3, image 1 de 2 VooDooQuad  250 Propeller Replacement: étape 3, image 2 de 2
    • Gently remove the propellers perpendicular to the device.
    • When placing the new set of propellers on the drone, make sure that the wings angled upward are facing towards the center, or the battery.
Be careful removing the bolts multiple times because it may create slippage and then this will not allow the bolt nor the propeller to stay on. To reassemble your device, follow these instructions in reverse order
Damir Pamic
Membre depuis le 02/15/17
141 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 10-3, Remmell Spring 2017 Membre de l'équipe USF Tampa, Team 10-3, Remmell Spring 2017
USFT-REMMELL-S17S10G3
4 membres
1 tutoriel rédigé
1 commentaire de tutoriel
Where do I purchase new perpelers
Will Smith - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 10
Total : 588
