Aller au contenu principal
Wahl Professional Designer Power Switch Replacement
Sophia Swearengin
Sophia Swearengin et un autre contributeur
Dernière mise à jour le July 15, 2024
5 minutes
Modérée
Use this guide to replace the power switch on your device.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Wahl Professional Designer Power Switch Replacement, Power Switch: étape 1, image 1 de 2 Wahl Professional Designer Power Switch Replacement, Power Switch: étape 1, image 2 de 2
    • Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
  2. Wahl Professional Designer Power Switch Replacement: étape 2, image 1 de 2 Wahl Professional Designer Power Switch Replacement: étape 2, image 2 de 2
    • Unscrew the two black 5.556 mm Phillip head screw on the power switch with a Phillips #0 Screwdriver.
  3. Wahl Professional Designer Power Switch Replacement: étape 3, image 1 de 3 Wahl Professional Designer Power Switch Replacement: étape 3, image 2 de 3 Wahl Professional Designer Power Switch Replacement: étape 3, image 3 de 3
    • Shimmy the power switch off the mount until it is completely removed.
Sophia Swearengin
Membre depuis le 09/26/17
790 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S14-G5, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S14-G5, Boczar Fall 2017
USFT-BOCZAR-F17S14G5
2 membres
10 tutoriels rédigés
1 commentaire de tutoriel
Hello Mrs/ms Swearengin, I’m disassembled my Wahl desingner I’m unable to make the power switch stiff . It’s very loose I can’t recall which screw goes in between two black 5.556 mm Phillip head screw or if it needs a screw at all
Carlos Olvera - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 705
