Wii U GamePad Outer Case Replacement
Introduction
Passez à l'étape 1This guide will help you to remove the outer case and be able to open the Nintendo Wii U Gamepad. You will need a Tri-point Y1 screw driver.
Ce dont vous avez besoin
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
5 autres ont terminé cette réparation.
2 commentaires
This doesn't show anything about taking the front of the housing off, is that relatively straightforward?
This doesn't show anything about the L and R sticks like moving on its own when i play, do you how to fix that?
