Aller au contenu principal
Wolf Gourmet WGBL100S Power Cord Replacement
Cole Gillespie
Cole Gillespie et 3 autres contributeurs
Dernière mise à jour le August 1, 2019
15 - 20 minutes
Modérée
If your power cord is broken and your blender will not turn on, follow these steps to replace it.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Wolf Gourmet WGBL100S Power Cord Replacement, Power Cord: étape 1, image 1 de 2 Wolf Gourmet WGBL100S Power Cord Replacement, Power Cord: étape 1, image 2 de 2
    • With the bottom of the blender facing up, use a Phillips #2 screwdriver to remove the 4, 1/2 inch long screws in the corners of the device.
    • Ensure the blender is off and unplugged before starting.
  2. Wolf Gourmet WGBL100S Power Cord Replacement: étape 2, image 1 de 2 Wolf Gourmet WGBL100S Power Cord Replacement: étape 2, image 2 de 2
    • Using a metal spudger, pry up one side of each of the rubber feet.
    • Note that one side of each foot is glued down; pry up the non-glued side.
  3. Wolf Gourmet WGBL100S Power Cord Replacement: étape 3, image 1 de 1
    • Using the same Phillips #2 screwdriver, unscrew the 1/2 inch long screw under each of the feet.
  4. Wolf Gourmet WGBL100S Power Cord Replacement: étape 4, image 1 de 2 Wolf Gourmet WGBL100S Power Cord Replacement: étape 4, image 2 de 2
    • Pull off the base and remove the plastic housing underneath.
  5. Wolf Gourmet WGBL100S Power Cord Replacement: étape 5, image 1 de 2 Wolf Gourmet WGBL100S Power Cord Replacement: étape 5, image 2 de 2
    • On the underside of the base, unscrew the three 3/8" long screws on the plastic piece holding the power cord in place using a Phillips #1 screwdriver.
    • Pull the plastic cover off.
  6. Wolf Gourmet WGBL100S Power Cord Replacement: étape 6, image 1 de 1
    • Using a wire cutter, cut the three wires of the power cord.
  7. Wolf Gourmet WGBL100S Power Cord Replacement: étape 7, image 1 de 2 Wolf Gourmet WGBL100S Power Cord Replacement: étape 7, image 2 de 2
    • Pull the cut power cord through the base.
    • Then thread the replacement cord back through and re-attach the plastic cover.
  8. Wolf Gourmet WGBL100S Power Cord Replacement: étape 8, image 1 de 3 Wolf Gourmet WGBL100S Power Cord Replacement: étape 8, image 2 de 3 Wolf Gourmet WGBL100S Power Cord Replacement: étape 8, image 3 de 3
    • Strip about an inch of insulation off of the snipped power cord and your replacement cord.
    • Twist each strand of wires together to keep them neat.
  9. Wolf Gourmet WGBL100S Power Cord Replacement: étape 9, image 1 de 2 Wolf Gourmet WGBL100S Power Cord Replacement: étape 9, image 2 de 2
    • Twist together the wires from the replacement cord to the wires still attached to the blender.
    • Solder the connection if possible.
  10. Wolf Gourmet WGBL100S Power Cord Replacement: étape 10, image 1 de 2 Wolf Gourmet WGBL100S Power Cord Replacement: étape 10, image 2 de 2
    • Wrap all the connections in electrical tape or heat shrink tubing.
To reassemble your device, follow steps 1-5 in reverse order.
Cole Gillespie
Membre depuis le 04/19/18
476 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S25-G16, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S25-G16, Maness Spring 2018
CPSU-MANESS-S18S25G16
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 7
Total : 312
