Aller au contenu principal
ZTE ZFive G LTE Volume and Power Button Replacement
Julian Mendoza
Julian Mendoza et 3 autres contributeurs
Dernière mise à jour le May 7, 2024
10 - 15 minutes
Modérée
This is not a guide for replacing the switch assembly, only for replacing the plastic covers to the buttons.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: étape 1, image 1 de 3 ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: étape 1, image 2 de 3 ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: étape 1, image 3 de 3
    • Remove back cover of the device from the crease of the bottom left corner using opening tool or fingernail.
  2. ZTE ZFive G LTE Volume and Power Button Replacement: étape 2, image 1 de 2 ZTE ZFive G LTE Volume and Power Button Replacement: étape 2, image 2 de 2
    • Remove the battery with an opening tool or fingernail.
  3. ZTE ZFive G LTE Volume and Power Button Replacement: étape 3, image 1 de 2 ZTE ZFive G LTE Volume and Power Button Replacement: étape 3, image 2 de 2
    • Unscrew all 16 screws from the mid-frame with a J000 screwdriver.
  4. ZTE ZFive G LTE Volume and Power Button Replacement: étape 4, image 1 de 2 ZTE ZFive G LTE Volume and Power Button Replacement: étape 4, image 2 de 2
    • Being careful with the device, gently pull up the device body tugging from the inside of the device.
    • Be sure to pull away from the device.
  5. ZTE ZFive G LTE Volume and Power Button Replacement: étape 5, image 1 de 2 ZTE ZFive G LTE Volume and Power Button Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • Carefully use a pair of bent nose tweezers to pull out the button cover. I should come out easily.
Julian Mendoza
Membre depuis le 09/21/18
728 Réputation
5 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 360
