Zerodate T26 Side Button Sensors Replacement
Introduction
Passez à l'étape 1If the side buttons of your Zerodate T26 mouse have been severely damaged and need to be replaced, or you just wish to clean them, follow the steps on this guide. For this replacement, you need a plastic opening tool, a soldering iron, and a Phillips #00 screwdriver. Replacement buttons can be ordered online if needed.
Ce dont vous avez besoin
Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
Take out the battery obstructing movement. This should now allow you to gently pull the circuit board up from the bottom of the mouse.
