Aller au contenu principal
Zoomer Jurassic World Indominus Rex Motherboard Replacement
Anh Le
Anh Le et 3 autres contributeurs
Dernière mise à jour le May 7, 2024
30 minutes - 1 heure
Difficile
Tutoriel étudiant vedette
Motherboard is the most important component of a Zoomer Jurassic World Indominus Rex. If all else fails, we can always replace the motherboard. Knowing how to solder before attempting this guide is extremely encouraged. Details about soldering technique guide can be found at the last step of this guide.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Zoomer Jurassic World Indominus Rex Motherboard Replacement, Back Cover: étape 1, image 1 de 1
    • Turn off and unplug Zoomer Jurassic World Indominus Rex from any power source before doing replacements.
    • Remove all eight (8) 9.3mm Phillips screws using Phillips #1 screwdriver.
  2. Zoomer Jurassic World Indominus Rex Motherboard Replacement: étape 2, image 1 de 2 Zoomer Jurassic World Indominus Rex Motherboard Replacement: étape 2, image 2 de 2
    • Pry apart the back cover of the Jurassic Indominus Rex and the rest of the body using a spudger.
    • Do not take out the back cover immediately as it it still attached to the motherboard by a wire.
  3. Zoomer Jurassic World Indominus Rex Motherboard Replacement: étape 3, image 1 de 2 Zoomer Jurassic World Indominus Rex Motherboard Replacement: étape 3, image 2 de 2
    • Disconnect the orange wire that connects the motherboard and the back cover.
    • Separate the back cover and the rest of the Zoomer Jurassic World Indominus Rex.
    • Gently press the tab on the side of the orange connector if you are having trouble disconnecting the wire.
  4. Zoomer Jurassic World Indominus Rex Motherboard Replacement, Motherboard: étape 4, image 1 de 2 Zoomer Jurassic World Indominus Rex Motherboard Replacement, Motherboard: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    • Let the toy rest firmly on a flat surface before processing to the next step.
    • Gently pull each wire out of the connector on the motherboard. Use a set of tweezers, if necessary.
  5. Zoomer Jurassic World Indominus Rex Motherboard Replacement: étape 5, image 1 de 2 Zoomer Jurassic World Indominus Rex Motherboard Replacement: étape 5, image 2 de 2
    • Remove the two (2) #0 7.5mm phillips screws from the left side of the motherboard.
    • Remove the one (1) 7.5mm #0 phillips screw from the right side of the motherboard.
  6. Zoomer Jurassic World Indominus Rex Motherboard Replacement: étape 6, image 1 de 1
    • Use a soldering iron to remove the red and black wires from the motherboard .
    • Soldering technique guide from iFixit can be found here.
    • Use caution while soldering to avoid being burned.
Anh Le
Membre depuis le 01/20/16
504 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 10-3, Remmell Spring 2016 Membre de l'équipe USF Tampa, Team 10-3, Remmell Spring 2016
USFT-REMMELL-S16S10G3
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 19
Total : 876
