iMac Intel 21.5" EMC 2308 Bluetooth Board Replacement
Introduction
Passez à l'étape 1Use this guide to replace a broken Bluetooth board.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Use the flat end of a spudger to pry the Bluetooth antenna cable connector up off the Bluetooth board.
2 autres ont terminé cette réparation.
1 commentaire de tutoriel
Seriously this is so incomplete! What about the cable that connects the Bluetooth to the logic board!?!??? Like this is so half way explanatory!
