Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iPod 3rd Generation Headphone Jack Replacement
Ce dont vous avez besoin
  1. iPod 3rd Generation Headphone Jack Replacement, Case: étape 1, image 1 de 1
    • Before opening your iPod, ensure that the hold switch is in the locked position. The orange bar should be visible, indicating hold is active.
    Demander à FixBot
    Ajouter un commentaire
  2. iPod 3rd Generation Headphone Jack Replacement: étape 2, image 1 de 3 iPod 3rd Generation Headphone Jack Replacement: étape 2, image 2 de 3 iPod 3rd Generation Headphone Jack Replacement: étape 2, image 3 de 3
    • Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
    • You may need to rock the pick back and forth to slide it in farther.
    • Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
    • Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
    • After all five tabs along the right side are free, the case should open easily.
    Demander à FixBot
  3. iPod 3rd Generation Headphone Jack Replacement: étape 3, image 1 de 1
    • The iPod case is now open, but don't separate the two halves just yet. There is still an orange ribbon cable connecting the headphone jack to the logic board.
    • Open the case like a book with the dock connector at the top, and lay the rear panel next to the front half of the iPod.
    Demander à FixBot
  4. iPod 3rd Generation Headphone Jack Replacement: étape 4, image 1 de 2 iPod 3rd Generation Headphone Jack Replacement: étape 4, image 2 de 2
    • Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
    • The headphone jack connector is unusually tall. When prying, be careful to not separate the lower, plastic part of the connector from the ribbon cable. Pry between the connector and the socket, not between the two halves of the connector.
    Demander à FixBot
  5. iPod 3rd Generation Headphone Jack Replacement, Headphone Jack: étape 5, image 1 de 1
    • Remove the 3 silver Philips screws securing the headphone jack to the rear panel.
    Demander à FixBot
  6. iPod 3rd Generation Headphone Jack Replacement: étape 6, image 1 de 1
    • Slide a spudger beneath the orange headphone jack cable and use it to pry the cable up from the rear panel.
    Demander à FixBot
  7. iPod 3rd Generation Headphone Jack Replacement: étape 7, image 1 de 1
    • Grasp the headphone jack board and lift it out of the iPod.
    • When reassembling your iPod, be sure that the plastic hold switch mechanism is synced with the hold switch on the logic board. The switch on the board is a small black nub that sits in the slot on the hold switch mechanism.
    Demander à FixBot
11 autres ont terminé cette réparation.
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
1 commentaire de tutoriel
When replacing the jack, should you put the copper tape back on the new part?
Chester Riches - Réponse Partager
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 26
30 derniers jours : 112
Total : 33,549
